FS-527exit roll noise
  • mascan42
    • Oct 2008
    • 484
    I have a Bizhub 652 with an FS-527 finisher. When the exit rolls close to eject the page, it moves normally (closes fully, not abnormally slow or fast) but it makes a loud CHUNK noise.
  • allan
    RTFM!!
    • 5462
    Re: FS-527exit roll noise
    Did you strip it to check for adjustment?
    Whatever
    • Glaander
      • Oct 2010
      • 33
      i worked on one 2 weeks ago, I got squeaking noise, the solution for me was the metal guard with a few rollers on them, when you open the door, you see a metal lever to pull down to release a metal guard plate, that guard plate got a few rollers on them and those roller need oil, rust was build up there.
      at your video, you hear the metal chunk when paper pass by there, I think is that metal plate roller hard to turn and vibrate, I might be wrong tho.
      • Issac-brock
        • Jan 2015
        • 61
        Thanks, this just helped me. Couldn't Quite pinpoint the squeek. Turned out to be the 4 white idle rollers above the ones you mentioned. Took apart enough to release these from touching and the noise stopped. Some oil and all good.
