Hello there, can somebody give me information about the functions of the two limit switches that are actuated whenever the front door is closed?
These 2 switches are actuated when the door is closed together with the front door interlock switch (white color switch).
I have no wiring diagram on this model. I,m trying to analyze if it has something to do with F28-2 code which is Transfer problem (arching) or HV2.
If the two limit switches has something to do with HV, maybe i'll try to short the switches to isolate the problem.
thanks in advance.
thanks in advance.
