New C754e jamming 220gsm and 300gsm SRA3
  • Guy Milner
    • Nov 2013
    • 61
    [Jamming] New C754e jamming 220gsm and 300gsm SRA3
    Hi,
    I have a brand new C754e in a customer's print room. It just doesn't want to feed their 220gsm and 300gsm SRA3 Xerox copy paper/card.
    The 300gsm jams every time, just as it gets through the bypass pick up and into the machine. The 220gsm is a bit more random but normally jams every 3 or 4 and jams in the same area. The thick 3/4 settings are being used correctly. Normal sized A3 80gsm, from bypass, no problem at all.
    Has anyone had these sorts of issues ?
    Is it the Xerox paper possibly ?
    I tried the same paper on a C454e and it also jams, but the 300gsm did manage 5 this time !
    Or does anyone have any recommendations of the best media to use on Konica Minoltas ?
    Your help is appreciated.
    Guy
  • wseyller
    • Sep 2012
    • 1129
    Re: New C754e jamming 220gsm and 300gsm SRA3
    Originally posted by Guy Milner
    Hi,
    Guy
    Here is a media guide. It is for US paper size but maybe it will give you some insight.
    I noticed too in the service manual that paper conveyance is not guaranteed for thick4.
    Media+Guide_Sales_and_Service.pdf
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      WHAT is the jam code?
      • ivovb
        • 695
        In Europe it is Color Copy (Mondi - Color Copy) recommended. There is some problem with cutting Xerox paper that is making edge of paper...
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • hotfuser
          • 180
          BR
          I have loads of issues with Xerox paper even the 80gsm paper. Mondi is the recommeneded media for KM machines I have no problems with this at all.
          • Guy Milner
            • Nov 2013
            • 61
            We found out that the machine just can't handle coated paper / card, especially if pushed to 300gsm.
            • barber782
              • Aug 2011
              • 286
              I know that there is an extra spring above the separation assembly which adds a tiny bit of tension during paper separation. 454e feeding 300gsm from bypass.
              • barber782
                • Aug 2011
                • 286
                Spring located under black plastic cover on top of separation assembly. Open right door and look inside down where the bypass is. Remove small black cover 2 x screws on top. Tiny Spring inside white plastic separation assembly.
