Bizhub c451 Problme with cayn. Spots
  • irakli3443
    • Sep 2010
    • 42
    How do I remove these spots?
    And what is broken?
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub c451 Problme with cayn. Spots
    What are you copying? It looks like you have just closed the ADF and made a copy of the platen cover. Same junk on both sheets of paper. If this is the case then clean the white cover. Emujo
    • irakli3443
      • Sep 2010
      • 42
      it's from Ms Word print out
      • irakli3443
        • Sep 2010
        • 42
        somebody can help me how clean this spots
        • Synaux
          • Mar 2012
          • 1224
          Have you tried replacing the Cyan Imaging Unit?
          • irakli3443
            • Sep 2010
            • 42
            it's new. only 1k metter.
            how i clean it or clean from programe
            • allan
              RTFM!!
              • 5462
              Do a half tone at value "0" for cyan that would be interesting to see if it appears on there. Also what is your TCR% ? Could be a bad contact.
              Whatever
              • irakli3443
                • Sep 2010
                • 42
                i don't know haw make - half tone at value "0".
                and where can i'll search TCR?
                I'm new in this machine system. please write me how make that steps.
                • allan
                  RTFM!!
                  • 5462
                  Go to service mode -> Test mode -> Halftone pattern -> use number keys to change value and select cyan load paper and press start . useful to IU condition.
                  Go to SM -> State confirmation -> Level History 1 (note if no print have been made TCR values would be 0) a good Toner to Carrier Ratio is 6.5% toner but from 4% to 8% is acceptable.
                  "0" is supposed to create no image and "255" max density.
                  Whatever
                  • irakli3443
                    • Sep 2010
                    • 42
                    TCR-C = 6.40
                    • allan
                      RTFM!!
                      • 5462
                      Do a half tone at "0"
                      Whatever
                      • irakli3443
                        • Sep 2010
                        • 42
                        I did it. but when I scan. But after A scan, it will no longer be seen. there is little spots.
                        how can troubleshoot machine
