konica minolta bizhub 200 freezing
  • brent
    • Nov 2008
    • 1214
    0x01100003 is the code it gave the other day.. and it has been acting up I get a call every day on it. and could never catch it messing up.. today it did not code out but they were copying and it froze and said printing.. and nothing was happening.. it is a copier only by the way.. nothing hooked up to it.. it has a board going out it seems. any thoughts? thanks
    brent
  • brent
    • Nov 2008
    • 1214
    Re: konica minolta bizhub 200 freezing
    just thought if anyone had any thougts before I started replacing boards.. I am going to do some more research on it today
    if anyone had any information.. thanks
    brent
    • darry1322
      • Oct 2010
      • 817
      brent
      Bad MFB board will cause this.
      • speedtek
        • Apr 2013
        • 46
        ^^^sorry I had the reply open for a while before I hit Submit!
        According to KM that code indicates a bad MFBS Board.
        • brent
          • Nov 2008
          • 1214
          of course.. the most expensive board.. lol right?
          thank you guys
          brent
          • mo0651
            • 1054
            Had 1 freezing up when the toner level was off and not replenishing... Is anything running or just sitting there?
            • brent
              • Nov 2008
              • 1214
              Nope it would just say printing and it was completely stopped and I replaced the board today and it seems to have fixed it thank you for your help
              • brent
                • Nov 2008
                • 1214
                replaced the board. was fine for 2 days. today it aborted and is s tuck again. I guess I am kind of at a loss 0x0110000003 is what the code was the first time
                I replaced the mfb board. any thoughts.>
                brent
                • Hansoon
                  • Sep 2007
                  • 3402
                  Not out of experience but my guts are telling me power supply.
                  Hans
                  • brent
                    • Nov 2008
                    • 1214
                    ok it crapped out on me today as well. so I have it back at the shop customer claimed the tried to make a 2 sided copy today and it went into freeze mode
                    they do a 2 sided on the 1 to 2 mode.. and one side is a reduction on legal then 100 percent on the second side.. I give up..
                    I am back at the shop and I can not replicate it.. it works here.. here are a couple more other items.. the drum is scratched by the transfer roller right to the aluminmum I had not noticed that till today. and the fuser is worn down to the metal by the famous thermistor.. these could be a contributor to the problem and I just thought I would update this problem for ya'll the sad thing.,. is this machine has 114k on it.. and in a low volume environment really took a toll on this machine..
                    thanks
                    brent
                    • mjunkaged
                      • 387
                      thanks
                      brent
                      THE SCRATCHED DRUM can cause your charge wire to short, causing 'scrambled brains'. Had a similar issue with a customer who didn't want to replace the drum for awhile. I believe a new drum made his stop acting screwy...but i did BCS board (inside scanner) as well as starter and dev. unit (worn out) as well.
                      • Hansoon
                        • Sep 2007
                        • 3402
                        mjunkaged is right. This is a well known cause for freezing, aborts and the like.
                        Hans
                        • Frostwolf
                          • 71
                          Check for swollen caps on power supply, I've seen a couple of Dialta 3510's and bizhub 350's with caps swelled up. Should be able to see them without taking it out of the machine.
                          Good Luck
                          • brent
                            • Nov 2008
                            • 1214
                            here is the latest with the darn machine.. I brought it to the shop and it freezes up still.. reset. then it threw a 0x00e00317 witch shows a mem board
                            so I replaced it.. and no dice.. I simply swapped a drum unit from another machine. problem goes away. but I don't know if this is it or not.. it must have been arching.. but like with anything else.. I am very leary
                            brent
                            • fixthecopier
                              ALIEN OVERLORD
                              • 4713
                              I had a bizhub 200 throwing an error for the fan. Drum shorts can cause funny things. Do you have new collars in the dv boxes?
