Bizhub 552 tray 3 lift motor
  • mascan42
    • Oct 2008
    • 482
    One of the claws that hold the gear on the end of this motor has broken, so any time I open the drawer, it pops off. Considering that the motor is mounted behind a dozen major assemblies, and removing it is a good 3-4 hour job, is there any way to repair this without removing the motor?
  • methogod
    • Dec 2008
    • 919
    Re: Bizhub 552 tray 3 lift motor
    try super glue, or that plastic you can melt in hot water, see if you can repair the broken connector - see it done before.
    but if not you can get the the lower tray lift motors in about an hour.
    • mascan42
      • Oct 2008
      • 482
      Is there some easy way to get at the motor that I'm missing? I have to remove the power supply, the PWB box, the paper feed drive board, the vertical transport unit, and the LCC drive unit in order to even see the thing.
      • methogod
        • Dec 2008
        • 919
        you can pull tray out and whichever panel side its on. its some work but less then going from the back...
        you can always blame it on the customer and make it chargeable.... it brakes from customers slamming the trays, especially when full.
        • mascan42
          • Oct 2008
          • 482
          Wish I could bill them, but they tend to complain about the slightest thing, so I have to kiss their ass every time I walk in the door.
          • PeterG
            • Jul 2008
            • 177
            Yeah, attack it from the front. It is pretty easy really. Remove the paper tray & undo a couple of screws. By far the hardest part is plugging the harness back into the motor. You sort of need three hands for that part.
            Oh! Hot tip, remember to turn off the tray heaters before you start. It is bad enough reaching in to get at the back, but roasting your arms whilst doing it sucks.
