c552 fan error code for card cage
  • wd40hoehandle
    • Jul 2025
    Do not have the error codes list for this product- is there a code for faulty fan on the card cage that holds fax and nic card?
    and will unit shut down and not connect to network and or problems with fax if this error code appears?
    On the older units like a 75 we could pull the error codes is that still the same on the c552 or similar in tech mode?
    Thanks for any info, gotta be on site tomorrow!
