Konica Minolta Bizhub 250 error C2211 and C5102
  • mirci
    [Error Code] Konica Minolta Bizhub 250 error C2211 and C5102
    Hello everybody
    I ask for your help in a problem I'm having with this copier. When I start the machine in the morning it shows an error C2211, then, after few times of turning it off and on, it shows C5102. After about 2 hours, the room the machine is gets warmer, it works perfectly with no errors until next day. I know that C5102 it's about the main motor, but I thought that these errors might mean something different and would ring a bell for someone.
    Thanks for help
  • mrwho
    Major Asshole!
    • 4299
    Re: Konica Minolta Bizhub 250 error C2211 and C5102
    Swap the main motor with the developing motor next to it and see if the symptoms change.
    Mascan42
    Ibid
    • laitang
      • Nov 2012
      • 627
      Check Power Supply Unit, it supply current for IU motor (code 2211) and main motor (code 5102).
      • hoyko
        Originally posted by mirci
        Hello everybody
        Thanks for help
        • mirci
          First thanks to all for support.
          I found a second hand main motor which was taken from a working machine. I said that, if I didn't spend anything for this I should try to replace this motor and see if the problem is fixed.
          Later edit
          I read here that, in order to get to the main motor I have to take apart the cage containing the MB containing the hard drive. It's a little confusing for me because, as I took apart the metal plate I could see clearly the main motor.
          • mirci
            I got the main motor(m1) replaced and now it's only showing c2211 error in the morning. After few tries(about 1 hour) it works perfectly, the only thing is some squeaking ans screeching coming from the IU which also disappear after a short while. Do you think that IU is dying or is a power supply problem?
            Thanks.
            • mrwho
              Major Asshole!
              • 4299
              I'd try IU first. Easier and cheaper.
              Mascan42
              Ibid
              • mirci
                Hi guys. Sorry for the late response, problem solved. It is temperature problem, this machine doesn't work in low temperature conditions. I just increased the room temperature and it works perfectly. Maybe it's a common issue with this brand because I have a Ricoh Aficio 1022 that works in the same conditions and no problem like that.
                • allan
                  RTFM!!
                  • 5462
                  Remove the fuser while cold and check if its stiff.
                  Whatever
