Color variation.
+ More Options
Posts
  • Supriecia
    • Jan 2015
    • 3
    Color variation.
    Color variation on heavy paper in the bizhub Pro C6500
    Any tips?
  • smart-refill
    • Jan 2012
    • 27
    Re: Color variation.
    hello
    this variation of color is present only on the black?
    • Mick01
      • Nov 2012
      • 362
      Hi,
      good luck trying to get an even print just using black. Having said that though you should be getting a better output than that.
      By looking at your sample it appears that your Black drum might need replacing. I would also try printing the job in a Line screen.
      • Supriecia
        • Jan 2015
        • 3
        Originally posted by smart-refill
        hello
        yes, but only a half step , the stoned is Normal
        • Supriecia
          • Jan 2015
          • 3
          Originally posted by Mick01
          Hi,
          Hello,
          The revealing black unit is new, and it just happens to use thick paper (240 grams or more) and quietly, if dark is normal.
          • mrwho
            Major Asshole!
            • 4299
            Paper Setting -> Choose the tray where the paper is -> Change -> Process Adj. -> Set "Separation DC Front" and "Separation DC Back" to -30 and see if it improves.
            Mascan42
            Ibid
