konica c250 exit switch
  • DOE
    • Mar 2010
    • 258
    can you buy the konica c250 exit switch assembly by itself or do you have to buy a new fuser. the plastic was brittle and fell apart. i have replaced fuse so at least fusers second go around
  • Dickie
    • Nov 2011
    • 190
    Re: konica c250 exit switch
    Never been available in the U.K the best work around is to keep the old fusers from the chargeable calls and use them to either replace the whole unit or just use the exit flag.
    • Blizzoo
      • Aug 2013
      • 610
      I know just the exit sensor flag have a p/n.
      • DOE
        • Mar 2010
        • 258
        does anyone kn ow the part number for the flag for the c250 fuser. sorry but i dont have a parts manual. thanks
        • hotfuser
          • 180
          the part number is 4038 5728 03 actuator
          • hotfuser
            • 180
            the part became available as it is in the 2008 version manual
