BH36/42 HDD MEMORY FULL when scanning
  • splblazer91
    • Jul 2014
    • 204
    Anyone run into this? I replaced the HDD and the customer called back 3 days later with the same issue. If they power cycle the machine resumes scan function again.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: BH36/42 HDD MEMORY FULL when scanning
    C35 which uses the same scanner also has this bug when compact PDF is used and there is a dirty background on the originals. Special firmware illiminates the problem.
    I have not checked for the B36/42 as they are an exceptionally rare machine in my part of the world.
    • allan
      RTFM!!
      • 5462
      Yes I did more than one for diverent errors consirning hhd errors and scaning problems there is a firmare fix for that. For errors on ftp scan you can swith of compact pdf and it will work without the error. Also smtp scan gives an error from the server. Give me a minute and I will get the bullitin about that
      Whatever
      • allan
        RTFM!!
        • 5462
        VER-A3EW-30G2-0902-05_Insufficient HDD
        Whatever
        • JR2ALTA
          • Feb 2010
          • 2033
          I replaced the MFP board for this issue. Had an open ticket with Konica, got it under warranty and it worked.
          • splblazer91
            • Jul 2014
            • 204
            Thanks for the responses. I will download and try the FW first.
            • pgramolini
              • Sep 2014
              • 19
              Check to make sure the customer isn't storing their personal files on the hard drive, if it is shared on their network. Hmmm what to do with 300 Gig...
              • pgramolini
                • Sep 2014
                • 19
                Then again... I think the HD capacity is something like 250 GB, so that is rather silly. But I guess it is pertinent to make sure they are not storing personal files...
