Solving "Licence Error" messages without access to LMS
  • mrwho
    Major Asshole!
    • 4299
    Good evening everyone.
    I've got a handful of machines wich, for several reasons (board replacement, NVRAM replacement, FW update), have the dreaded Licence Error message.
    Is it still imperative to have access to LMS to get around this or is there another procedure?
    Cheers!
    Mascan42
    Ibid
  • Synaux
    • Mar 2012
    • 1224
    Re: Solving "Licence Error" messages without access to LMS
    Cheers!
    Maybe someone will correct me, but I believe you still need to go through the LMS procedures.
    What models?
    • mrwho
      Major Asshole!
      • 4299
      C451 and I believe a C353 or similar.
      Mascan42
      Ibid
      • Synaux
        • Mar 2012
        • 1224
        Definitely then...
        • mrwho
          Major Asshole!
          • 4299
          Thank you
          Mascan42
          Ibid
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            Un till someone cracks the code and makes a key generator, then free LK's for all!
            • jotunn
              • 615
              Guys, I will tell you a secret... you can take _any_ valid pair of initialization code/serial number and use this as many times as you wish to repair _any_ machine with license management error.
              You can use for example this one - from BH421:
              MFP Serial Number: A0R6021006374
              Initialization Code: 2VRA4-UGGA2-Z2H4K-7AVUH-F58SW-J2Z7U-QVKVK
              It doesn't matter that you have a problem with C451 or C203 or C224e, just set above S/N in the machine and use above initialization code, then restart machine and set back original S/N, reboot again - license management problem will be solved.
              • mrwho
                Major Asshole!
                • 4299
                That's nice. Now if anyone had those for C451 and C353... 😊
                Mascan42
                Ibid
                • jotunn
                  • 615
                  No, no, you don't need initialization codes for particular machine types - as I wrote, they are interchangeable, so you can use BH421 serial+code to initilize C353 !!!
                  • mrwho
                    Major Asshole!
                    • 4299
                    That's even better! Need to try and get one. Thanks for the top tip.
                    Mascan42
                    Ibid
                    • habik
                      • 2013
                      That is interesting observation. Now if my C554e SSD PWB fails and I'll give it your serial for instance I doubt when I ask for replacement of SSD that the list output will be legit for warranty. Plus its a free tool to KM techs and it takes about 5 min anyway. Good for those who like to appear as newborn at the age of 700k + . But hey what do I know about fashion, retro is always in.
                      Sent from my iDon't believe in marketing device using Tapatalk
                      Firmwares HERE
                      • jotunn
                        • 615
                        OK for clarity, if you have a problem with "License management error" in _ANY_ machine type, please follow procedure below.
                        1. Go to the service mode and change machine serial number to A0R6021006374 (must be uppercase)
                        2. Reboot the machine (turn off/on main power switch)
                        3. Go again to the service mode, then [STOP]->[9], then [License Management]->[Initialize]
                        4. Use following initialization code: 2VRA4-UGGA2-Z2H4K-7AVUH-F58SW-J2Z7U-QVKVK
                        5. Reboot machine again
                        6. One more time go to service mode and set back your original serial number
                        7. Last reboot, and you should have no error
                        ANY means:
                        Bizhub 421/501
                        Bizhub 601/751
                        Bizhub 223/283/363/423
                        Bizhub 552/652
                        Bizhub 224e/284e/364e
                        Bizhub C203/C253/C353
                        Bizhub C220/C280/C360
                        Bizhub C224/C284/C364 also 'e'
                        Bizhub C454/C554 also 'e'
                        and so on...
                        • Synaux
                          • Mar 2012
                          • 1224
                          ANY means:
                          Bizhub 421/501
                          Bizhub 601/751
                          Bizhub 552/652
                          and so on...
                          haha that is awesome! (Not sure the public should have this info, but KM can go to hell with their "confidential" nonsense!)
                          • habik
                            • 2013
                            Now drop here a link for firmware patch, that gets rid off security dotted matrix and I'll stop using cash completely.
                            Firmwares HERE
                            • mrwho
                              Major Asshole!
                              • 4299
                              I'm so dense - You posted that and I didn't even see it! *facepalm*
                              Mascan42
                              Ibid
