BizHub C35
  • Cookr
    • Dec 2011
    • 184
    BizHub C35
    Working on customers BH C35 and they are getting a line down the page ONLY on copies and ONLY from the ADF copies just fine from glass and prints just fine also when you make a B&W copy its leaves a black line and if you make a color copy it leaves a magenta line. I have checked all the IU they look fine and also swapped out the belt with a used one and it did the same thing exact same spot, I have cleaned the glass and the slip also the laser lens under the IU's. Any Ideas? Thanks
  • Cookr
    • Dec 2011
    • 184
    Re: BizHub C35
    Here is a Photo of it
    • Zeldaman
      • Mar 2011
      • 946
      Re: BizHub C35
      Hi there!
      100% dust/dirt on the scanner. You have to open it (see service-manual) and clean it carefully.
      Greetings...
      • Cookr
        • Dec 2011
        • 184
        Re: BizHub C35
        Originally posted by Zeldaman
        Hi there!
        Greetings...
        OK. I'll give that a try but wouldn't affect it when I make a copy off the glass?
        • Zeldaman
          • Mar 2011
          • 946
          Re: BizHub C35
          Hi there!
          Nope, only via DF.
          Greetings...
          • allan
            RTFM!!
            • 5462
            Re: BizHub C35
            I will second that, Its on your slit glass or optics. Cleaning will fix this.
            Whatever
            • Cookr
              • Dec 2011
              • 184
              Re: BizHub C35
              That was it thanks
