PH UNIT K BIZHUB C353
  • backspace
    • Jul 2009
    • 54
    HI,
    Has anyone tried PUT PH UNIT (ANY c or K...) BIZHUB C203 / 253 IN The BIZHUB C353?
    tnx
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: PH UNIT K BIZHUB C353
    yes, you can and it works.
    the difference is the polygon motor is not rated for the higher RPM.
    it may work for a while or it may work forever, only time will tell. I have only done it temporarily with spare used ones till the correct new ones came into stock.
    • backspace
      • Jul 2009
      • 54
      Do I need and upgrade FW or not?
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        No, fw will make no difference
        • allan
          RTFM!!
          • 5462
          Good info. The engine speed should be the same on the 2 machines the time between paper feeds would be different. "Marketing bulshit"
          Whatever
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            paper movement speed is actually faster not just a lesser gap between pages.
            I seem to recall the c353 also has more cooling fans than the slower versions too.
            but in reality theres bugger all cost difference between manufacturing the slower machine compared to the faster one in the same engine type, it is just marketing bs.
            I know for a fact some cunning individuals have converted c203/c253 to operate as a c353 too.
            • hotfuser
              • 180
              Originally posted by backspace
              HI,
              tnx
              You can put a C353 PH in a C203/253 but the other way round i cant seem to get it too work due to the polygon motor speed.
              • habik
                • 2013
                That last paragraph is brilliant.
                Sent from my iDon't believe in marketing device using Tapatalk
                Firmwares HERE
                • Issac-brock
                  • Jan 2015
                  • 61
                  Just a note on this thread. Be careful ordering boards. I ordered the MFP to troubleshoot what turned out to be a bad laser in a new set and accidentally ordered a 353 mfp for my 253. Machine boots to hourglass forever. Won't make that mistake again.
                  In the end it was a faulty laser causing a "warming up" message then intermittently a laser code.
                  • D Colour
                    • Oct 2008
                    • 213
                    Hi all
                    We have a C200 showing C4153 (Y Laser issue). Can we use the lasers from a C203/C253/C353 to replace this faulty one?
                    James
                    Everything that has a beginning, has an end.....
                    • hotfuser
                      • 180
                      Originally posted by D Colour
                      Hi all
                      James
                      No they are unique
                      • D Colour
                        • Oct 2008
                        • 213
                        Originally posted by hotfuser
                        No they are unique
                        thanks! and bugger!
