Pdf conversion failed CWS
  • billy39
    • Dec 2014
    • 17
    Hi guys, seems to come across a problem that I am unable to figure out myself.
    Printing pdf files from CWS issue. Getting the following error
    If I export the pdf as jpg and then create pdf from it works.
    Any help is much appreciated
    BH C500PRO
    MAC OS X
    CWS 5.4
  • habik
    • 2013
    Re: Pdf conversion failed CWS
    BH C500PRO
    MAC OS X
    CWS 5.4
    Is this happening for Every PDF or just for one file?
    Are the layers flattened within the pdf it self?
    Are there any pictures on that pdf? If so what format they were put in the artwork as?
    Have you tried disabling the postscript in adobe print dialog under advanced "print as image" box to be ticked. (to see if postscript is the issue)
    How about driver version and fiery firmware and software version are they all up to date?
    Firmwares HERE
    • billy39
      • Dec 2014
      • 17
      It's happening to all pdf files. Artwork usually created in Adobe illustrator cs5.5, imposed in indesign cs5.5
      Currently I am exporting the pdf as jpg and printing. This method is not ideal as more work and quality is not crisp sharp for text
      How do I disable postscript & print as image? Is this done in CWS?
      Drivers are up to date
      Fiery x3ty embed controler
      Driver X3eTY 35C-KM PS v2.0
      • habik
        • 2013
        OK and what version of Fiery X3TY Software is at the moment? (In Fiery Menu> Print Configuration Page)
        Here is what I meant if you printing directly from Adobe Reader perhaps:
        Firmwares HERE
        • habik
          • 2013
          Other thing that popped in my mind is try and change in the same Advanced dialog the Font and Resource Policy to "Send for Each Page" if it is not grayed out.
          Firmwares HERE
          • billy39
            • Dec 2014
            • 17
            Hi? I am unable to print direct from pdf. I get the message ''printer in use" thou nothing is printing.
            I currently import the pdf file to CWS. I will check the fiery version today and get back to you on that,
