Konica Minolta Bizhub 352
  • kriss
    • Feb 2015
    • 16
    Hey guys.
    I would like to reset my admin password. I have a konica minolta bizhub c352 and I have follow your suggestions to get into service mode and have gotten all the way to the admin password and have changed it. However the change does not take. I type in a new password, hit end, then it ask me to retype the password. Then I hit end and it just sits there. If I keep hitting end it ask me to type in a new password again. Any idea what the problem could be?
    I would really appreciate your help.
    Mitch, I mailed you this question but wasn't sure if you got it. So I am asking it here.
    Please help anyone!
    Thanks,
    Kris
  • kriss
    • Feb 2015
    • 16
    Re: Konica Minolta Bizhub 352
    bump...
    still no answer?
    • Foxhound
      • Mar 2014
      • 33
      Just a reach; are there certain creiteria for the password? I.E Eight characters and or numerials etc. I'm pretty sure it needs to be 8 letters/numbers.
      • kriss
        • Feb 2015
        • 16
        You are right Foxhound and thanks for responding.
        It needs to be 8.
        The funny thing is that I get right up to the admin password and put it in, but it does not take. I enter a new one and re-enter it. Then I press end and it does not accept it.
        I even get to CE password but when I enter the one posted on this site starting with 9. It says it is not valid.
        Strange.
        I only need to change the IP address but to do this I need to get to the admin functions. Unless someone knows another way.
        What do you think?
        Thanks,
        Kris
        • Foxhound
          • Mar 2014
          • 33
          So just to catch up the default password of 12345678 does not work?
          • kriss
            • Feb 2015
            • 16
            Nope.
            I tried that as the admin password.
            Then I went into service mode and even tried to enter it there as the admin password but it would not take.
            • Foxhound
              • Mar 2014
              • 33
              Service mode should be 92729272
              • kriss
                • Feb 2015
                • 16
                yes that should be the CE password in service mode, right? I think that was changed because when I enter it in, it says the password is wrong.
                Anyway the point is that I cannot change the Administrator password in service mode. I try to change it but it hangs and does not accept the change.
                That's my core problem.
                • Foxhound
                  • Mar 2014
                  • 33
                  Sorry i'm not trying to be disrespectful, to enter service mode press utilities...select,check details, press stop-00-stop01, if it prompts for pass 92729272
                  • kriss
                    • Feb 2015
                    • 16
                    No I appreciate your help. Thanks so much.
                    I did that already. then I pressed, stop, zero, "c" and got the the password reset section. And from there I entered the password but it did not take.
                    • Foxhound
                      • Mar 2014
                      • 33
                      yeah sorry man, the only other thing i can think of is restore to factory default or wipe hdd. just for giggles use only numbers for your password. I'll keep an ear out, i may have some 2 series in my shop if i get some time.
                      • kriss
                        • Feb 2015
                        • 16
                        If I restored to factory default would that change the IP address? Or would that wipe out the administrator password function?
                        • kriss
                          • Feb 2015
                          • 16
                          anyone have an idea about this question?
                          • kriss
                            • Feb 2015
                            • 16
                            Konica Minolta Bizhub 352 change ip address without admin password?
                            How can I change the ip address in the bizhub c352 without the admin password?
                            I am putting a new one in but the system is not accepting it.
                            Or is it possible to reinstall the operating system totally. This system has a finisher installed with it.
                            Thanks,
                            Kris
                            • allan
                              RTFM!!
                              • 5462
                              I had a similar problem wit a B601 after swapping out the CF cards on 2 machines. The only way i could get back into admin was to do a CF card recovery.
                              Dont know if this is of any relevance.
                              Whatever
