C-2804
  • Pandas
    • Sep 2011
    • 14
    [Error Code] C-2804
    Hi.
    Power on bizhub 600 error 28-04.
    The machine i have new pm and new developer.
  • laitang
    • Nov 2012
    • 627
    Re: C-2804
    Did you reset the developer counter?
    C-2804
    :While in the gamma correction, the dirt correction of the gamma sensor is not sufficient
    • allan
      RTFM!!
      • 5459
      Re: C-2804
      Dirty Gama sensor. Even a spec of toner could cause this. The end connector on the IU also gets damaged from slamming the IU into place. If the problem persists replace the endblock and the sensor board.
      Whatever
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        Re: C-2804
        I have cleaned that sensor a hundred times.
        • Pandas
          • Sep 2011
          • 14
          Re: C-2804
          [QUOTE=fixthecopier;458744]I have cleaned that sensor a hundred times.[/QUOTE
          Yes .Not work
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            Re: C-2804
            [QUOTE=Pandas;458806]
            Yes .Not work
            then you should change it.
            • Pandas
              • Sep 2011
              • 14
              Re: C-2804
              [QUOTE=fixthecopier;458833]
              Ok.Thanks!!
