IC-408 FF
  • vlad_robas
    • Oct 2006
    • 225
    IC-408 FF
    Hi, I got FF on the Fiery so asked for a image. I have put the image on the USB and loaded on another 80 Gb HDD. It sayis instalation on progress wich take about 20-25 min and afther I'm asked to remove the thumb. Afther power on it load's and then restart. Load's again and black screen. That was doing with the original HDD too (without loading win). If I power on Safe Mode gives a blue screen right afther loading a file (I will complete later as now I'm trying again).
    My question is:
    On this kind of motherboard is instaled a modified version of bios? I cant acces any setting's in bios, I can only load default setting's or see the stats.
    Is there any update for bios? I'm thinking of some sort of problem becouse of the hdd settings (becouse the sistem isloading so slow).
  • vlad_robas
    • Oct 2006
    • 225
    Re: IC-408 FF
    Afther another try it is a succesfull install.
    It is working now.
    I don't know how to set time on it but it is working.
    Now I have C2814 but I read more here about it.
    • Synaux
      • Mar 2012
      • 1224
      Re: IC-408 FF
      My question is:
      fiery diag codes.pdf
      Some other things:
      Those heatsinks they put on there are with thermal pads and really suck. Get you some good thermal paste and clean off that old crap apply and reinstall.
      Hook up a CDRom to the Fiery and run memtest86
      Take the CMOS battery out to reset the BIOS.
      • Synaux
        • Mar 2012
        • 1224
        Re: IC-408 FF
        It is working now.
        I guess I posted almost the same time you posted. I would still take the time to do what I said with the heatsink.
        • vlad_robas
          • Oct 2006
          • 225
          Re: IC-408 FF
          I did it on CPU, almost first thing I did.
          Also i want to ask if this version's of FW are god or I should start looking for some newer versions.
          Print Engine A03U0Y0-00C1-G00-60
          Image Processor 1 A03U0Y0-00I1-G00-60
          Image Processor 2 A03U0Y0-00I2-G00-50
          Image Processor 3 A03U000-00I3-G00-6020
          Image Processor 4 -
          Image Processor 5 -
          Image Processor 6 -
          Image Processor 7 -
          Image Processor 8 A03U0Y0-00I4-G00-10
          Image Processor 9 A03U0Y0-00I5-G00-40
          FD-501 -
          SD-501 -
          FS-503 -
          FS-607/FS-520 A04D0Y0-00N2-G00-34
          LS-501 -
          RU-503/RU-504 -
          PB-501 -
          ADF A0520Y0-00F1-G00-10
