Bizhub 250 trying to reset error code
  • wseyller
    • Sep 2012
    • 1129
    #16
    Re: Bizhub 250 trying to reset error code
    Also another reason for the C2557 that you may want to take a quick look at. The toner adding solenoid on the toner drive assembly can stick if that foam pad wears off. It gets sticky if it does. See if the solenoid is engage as it will add too much toner to the Dev unit.
    It is possible to see this when removing the drum/IU.
    It is possible to get into tech rep mode if you reset the code and leave the right door and/or duplex door open. It will keep it from coding out and allow you to access it.
    • Victor285
      • Jul 2010
      • 61
      #17
      Originally posted by axyun
      Was getting intermittent C2557 and c2211 codes. Changed both motors and drive unit. The developer motor had badley damaged drive head from dv unit resistance. The other motor had resitand from transfer assembly which was a little gooky. Tookm it apart, cleaned it and lubed. Still getting c2557 and may need to change dv unit. Paper stop when going thru fuser with the c2557 code. Also machine not allow acknowledgement of trouble reset though i see that it is mentioned here to open right side door when doing it which i did not. Can't get into tech rep mode as it stays in reset mode and keeps cycling bact to dot on screen when you are supposed to press 3, then end, then trouble reset. This is getting crazy with time + cost. Wish i had a used machine for parts when i started.Starting to get disoriented. Help!!!. Frank
      After you see dot on screen, press 3, then enter access code and enter / exit. You should either get or read the manual.
      • Hansoon
        • Sep 2007
        • 3389
        #18
        That's what the guy did so what do you want to say Victor285??
        Hans
        • Brett GS
          • Jun 2013
          • 154
          #19
          Originally posted by Blizzoo
          You can manually adjust ATDC gain in smode : Tech. Rep.Choise ->Printer->ATDC sensor Gain.Take a look what is the current value and play a little with the values between 170 and 185 after you replace the broken gears, you may get rid of the 2557 code.
          I was going to suggest the same,i have pushed it up to 200 in order to clear 2557 code.
          Brett
          • axyun
            • Aug 2007
            • 1323
            #20
            I sold the customer a Ricoh Aficio MP2550. I have not picked up the 250 yet. Will do so next week and maybe continue to try to fix it. Thanks for all the help. I will post results when finished or if a new situation arises. Frank
            • Victor285
              • Jul 2010
              • 61
              #21
              Hans
              Doesn't matter now, as he replaced unit. Trouble reset is timed with rather short window for resetting or it continues cycling. 3, 00000000. trouble reset, exit.
