konica 7115 cof-32 code
  • DOE
    • Mar 2010
    • 258
    konica 7115 has a cof32 code on it and the toner light is on. replaced toner but still get cof32. is there a reset for this machine. have not worked on one for years and no manual. when switched on and off machine runs about 5 seconds and then get toner light and code but it doesnt appear to be trying to add toner. thanks for your ideas.
  • DOE
    • Mar 2010
    • 258
    Re: konica 7115 cof-32 code
    toner was empty when i got there and replaced cartridge
    • DOE
      • Mar 2010
      • 258
      does anyone know how to get into service mode?
      • Blizzoo
        • Aug 2013
        • 594
        Utility Stop 0 0 Stop 0 1
        I think it's time to change the developer and run F8 after that.
        Hope it helps.
        • DOE
          • Mar 2010
          • 258
          Hope it helps.
          thank you, really appreciate it.
          • DOE
            • Mar 2010
            • 258
            since the copier was run out of toner when code started i ran the toner replenish and when it was done copier went right to ready and was able to make copies. half hour later customer says cof32 is back. would you say only solution is to change developer or could it still be under toned.
            • Blizzoo
              • Aug 2013
              • 594
              Before replacing developer I would check toner hooper operation cheating front door and replenish, check and clean ATDC sensor underneath developing unit.Insuficient/worn developer will code out likewise.
