I have a strange fault on a C350( typically last call on Friday )
the machine sometimes will boot up to the ready sceen then shut down and the power up, it will do this 3 or 4 times befor it settles in the ready state, then when you try and take a copy it will freeze in the 'copying' state.
I have removed the hard drive and changed the memory with no luck,i have also put the lattest firmware on the machine . im going back on Monday to swap some boards with another machine.
Any one with any better ideas?
Cheers.
Cheers.
