Minolta Dialta Di 251
  • Techaus
    • 15
    Hi,
    Can anybody tell me what is the password for the admin management.Once I go to utility and admin management,it is asking for administrator code.Please help in this matter..
  • Gerg?
    • Jul 2008
    • 67
    try: sysadm
    • wagon
      Village Idiot
      • Dec 2006
      • 654
      Normally 0000 0000. Sometimes 0000 0001. I think.
      If you are hitting your head up against a wall it always feels better when you stop.
      • originalscore
        • Dec 2007
        • 7
        leave it blank
        • deep
          • Jun 2008
          • 208
          Try 00000000. You should be an Administrator to do that, or you will be.........
          Kenny
          • iraqi tech
            • Jul 2008
            • 20
            go to service mode then , then to input adminstration # , and you can set a new #
            • popcornpuppy
              • Jul 2008
              • 29
              its 12345678
              • Techaus
                • 15
                Minolta Dialta 251
                Hello all,I have tried all these..but not working at all.Possibly the default administration codehas been changed..how can I bring it back to default?I either do not know how to go to its service mode to do that..Please give me a help hand as I do not usually do minolta machines.
                • iraqi tech
                  • Jul 2008
                  • 20
                  If you can not enter into service mode , then you are not a tech, and this lead us to the point that you do not have the athourity to change the numbers.
                  • Techaus
                    • 15
                    My friend, I have been a technician for the last 8 years.But this is the first time I am doing a minolta machine and even I am not knowing how to go to its service mode..If u want to help proceed or just get lost...
                    • Hansoon
                      • Sep 2007
                      • 3389
                      Try to do as follows: Hit "Utility" on the keyboard, than "Counter" in the display, than "stop-0-0-stop-0-1" on the keyboard and finally hit "administrator input" in the display (2nd entrance) here you see the original admin # and here you can modify it. Good Luck! Hans
                      • stebro
                        • Aug 2025
                        It seems ALL forums are inhabited by "Wholier than Thous" I started as a tech 27 years ago and am now a business owner. I can still find time to help other people who have the guts to ask for help.. As my sweetheart says, "All people are just trying to get by in the world" Have some empathy guys.. you were there once!!
                        • lvangsnes
                          The administrator code can be changed in the service mode, or the admin mode (if you know the current password). If you are unable to enter the service mode because of a password issue, you might try a total clear, but only as a last resort. I have forgotten if there is an option after a warm restart if a tech password change can be done. Perhaps the security mode will allow it.
                          • Photoman
                            Hi, I had the same problem. Have you tried 0000? It asks for 8 digits, but this worked on mine. Good Luck.
                            • kmcopytech
                              • Dec 2007
                              • 141
                              Enter service mode , then to touch adminstration # , and you can check or set a new admin #
