how to resolve unresponsive touch panel bizhub 250
  • ivan
    • Feb 2015
    • 12
    [Misc] how to resolve unresponsive touch panel bizhub 250
    Hi,please help i have a bizhub 250 touch panel is not responding. sometimes it does after a few presses but some functions just dont accept is this a software related issue or must i change the panel
  • Elmo
    • Feb 2010
    • 541
    Re: how to resolve unresponsive touch panel bizhub 250
    replace it
    I Used To Live To Fix Things Now i Fix Things To Live
    • ivan
      • Feb 2015
      • 12
      Originally posted by Elmo
      replace it
      Thank you Elmo
      • Issac-brock
        • Jan 2015
        • 61
        Yes, replace it, had a BH350 recently, replaced and worked fine.
        • igor.sanfilip
          • Mar 2015
          • 11
          Only touch folie is needed to replace. Other boards on display are probably ok.
          • subaro
            • Oct 2010
            • 1274
            • igor.sanfilip
              • Mar 2015
              • 11
              You are right. Better word would be film , thin transparent film over the touch screen. IN most cases only film is needed to replace.Even film from minolta di 200 can fit.
              • allan
                RTFM!!
                • 5462
                Just got this problem the past week. A second hand machine is cheaper than the replacement panel.
                Whatever
                • igor.sanfilip
                  • Mar 2015
                  • 11
                  Its allways good to have some used machines arround .
