C6500 - IC408 Controller shuts down.
  • puupsol
    • Mar 2015
    • 9
    Hi
    I have Konica Minolta C6500 with IC408 Controller.
    After switching on and printing test page, controller shuts down itself. Controller goes to 91 and then shuts down.
    Tried software 2.0, 3.0, 1.0, 1.1, but still no luck.
    Can anybody advice, what it is and how can this be solved, any patch file or anything else. I am out of ideas.
  • RAI
    • Feb 2014
    • 44
    Re: C6500 - IC408 Controller shuts down.
    Is the controller software for the right manufacture? Shut down will happen if you try and load KM software on an Ikon box and same in reverse. It takes place after the OS loads and the Fiery SW starts. Approx 2 mins or so.
    • Mick01
      • Nov 2012
      • 362
      Hi,
      code 91 means the Fiery system has not updated.
      I would suggest the main culprit may be the HDD.
      I have attached the IC-408 service guide which may assist.
      Good Luck
      • puupsol
        • Mar 2015
        • 9
        Hi
        I have tried fresh HDD with fresh software.. Same problem...
        Originally posted by Mick01
        Hi,
        Good Luck
        • Mick01
          • Nov 2012
          • 362
          Hi,
          In that case I think Rai's suggestion is more than likely.
          Was this working previously? Check that you have the correct fiery system software for the IC-408.
          My thinking is the IC-408 now has screwed bias and sees the fiery system for a different manafacturer.
          The only way to recover this unfortunately is a mother board replacement (a very expensive option though)
          hope this helps.
          • puupsol
            • Mar 2015
            • 9
            Hi
            where can I buy mother board?? Can anybody help. I don't mind paying reasonable amount.
            • jotunn
              • 637
              Probably I can help you.
              Just make backup of BIOS from your controller, and send this backup file to me. Controller BIOS is Phoenix - Award BIOS (cooperation), so you should be able to use most of available tools for Award BIOS like awdflash - tools and tutorials from this site can be helpful: http://forums.mydigitallife.info/thr...shing-From-DOS
              • leo78rom
                Hi guys,
                Can anyone help me with the system software for IC-408. I have a C6500 and the controller went to FF yesterday and doesn't want to come back
                Unfortunately I don't have the CD
                Thank you
                Leo
                • tulintron
                  • Jul 2014
                  • 668
                  Hi,
                  Good Luck
                  Microsoft does not provide more system updates WinXP.
                  The controller executes the search for updates, find some, but not run. It may be the cause.
                  There came across system restarts, but I had problems with it.
                  • jotunn
                    • 637
                    That's completely beside the point.
                    You are describing known problem with working Fiery system, that can be usually solved by installation 1-1CO771 patch.
                    Subject of this thread is related to hardware/software problem (before stage of working Fiery system) - it's probably 2nd hand ICON controller and guy's trying to install Minolta software.
                    • Synaux
                      • Mar 2012
                      • 1224
