Bizhub C451 SKEW/REGISTRATION Isssues HELP!?
  • garyaird
    • Jun 2025
    Hi Guys,
    A few days ago I installed a new black IU in a bizhub c451 and it worked great, now the customer has called me back and the registration is out of wack..
    Any ideas? Cheers
  • allan
    RTFM!!
    • 5462
    Re: Bizhub C451 SKEW/REGISTRATION Isssues HELP!?
    You will get warning P-14 and P-21 reseat all the IU's and do a skew reset in service mode. Make sure the K unit is installed correctly, all the colors gets referenced from there.
    Whatever
    • habik
      • 2013
      Dude. This issue was posted and solved countless times. Search again!
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • habik
        • 2013
        Ah there might be issue with paper trays if you scanned this image from glass.
        Firmwares HERE
        • allan
          RTFM!!
          • 5462
          http://www.copytechnet.com/forums/ko...highlight=C451
          Whatever
