Need to disable automatic size detect on Bypass - Bizhub C284e
+ More Options
Posts
  • nenebrown
    • Oct 2010
    • 9
    [Misc] Need to disable automatic size detect on Bypass - Bizhub C284e
  • habik
    • 2013
    Re: Need to disable automatic size detect on Bypass - Bizhub C284e
    Have you tried custom size on the MFP?
    Firmwares HERE
    • nenebrown
      • Oct 2010
      • 9
      • emujo
        • Jun 2009
        • 3009
        Create a custom size, width can go to a short as 90 mm, length can be as short as 139 mm. Emujo
        • nenebrown
          • Oct 2010
          • 9
          The driver doesn't accept this values while using Mini banner. It changes to 210mm, instead of 193mm.
          Then I put 210 x 600, but in the MFP, when I adjust the tray to 193mm, the machine rejects the paper. And in the mini banner mode, the machine does'nt allow any adjustments in the screen.
          SnapCrab_NoName_2015-3-12_11-53-53_No-00.jpgSnapCrab_NoName_2015-3-12_11-53-39_No-00.jpg
          • emujo
            • Jun 2009
            • 3009
            When we do banners, we use Power Point as the file type and banner mode on the MFP. We create a custom size for the power point slide and is has always worked. I'm not sure what a mini banner is, but give it a try. Emujo
            • nenebrown
              • Oct 2010
              • 9
              • emujo
                • Jun 2009
                • 3009
                never heard of it (maybe it's a regional thing) but if you can't make any changes to the settings, then it looks like you will have to find the matching paper size to complete your mini banners. Emujo
                • 907tec
                  • 434
                  I would just put a shim in the bypass tray that holds your 193mm paper snugly and leaves the paper guides at 210mm. Adjust the document margins to make sure you don't print in the "extra" 17mm of paper that isn't there. Worth a shot anyways, and at least you'll figure out whether the rest of the paper path sensors will even accept 193mm paper.
                  • nenebrown
                    • Oct 2010
                    • 9
