Bizhub C552 - paper jam 3003
  • ECA
    • Dec 2014
    • 61
    Hi guys
    Been getting a jam when paper comes out of fuser into exit tray
    it only happened when i printer lots of sheets. but now is endlessly doing it. the service mode says jam 3003
    Its fans the paper, just as it comes out the fuser into the exit rollers (which are on the door)
    paper remains half in the fuser when you open the door
    i have looked everywhere but can't figure it out...
    even got a field manual in front of me. no details on it.
    any ideas?
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C552 - paper jam 3003
    Sounds like 2nd transfer roller is going bad. Emujo
    • ECA
      • Dec 2014
      • 61
      its doing this... (see red line where the paper is ending up)
      • emujo
        • Jun 2009
        • 3009
        If the fan fold is before the paper has entered the fuser (lead edge of the paper is in the fusing component), the 2nd x-fer roller is suspect. Emujo
        • ECA
          • Dec 2014
          • 61
          no it seems to be after the fuser. its exits the fuser trying to get into the exit tray on the door.
          ive taken the exit tray/rollers out and had a look around. nothing wrong (from a non expert eye)
          • ECA
            • Dec 2014
            • 61
            found and fixed
            major hidden folded paper bit of paper in the fuser... amazing how that A3 sheet fitted in there with being seen lol
            • emujo
              • Jun 2009
              • 3009
              Could be failed paper xport drive motor FTDB (p/n A0P0 H002 00), Improperly mounted actuator or failing exit sensor (PS39). Pull the fuser out and look for excessive play around the exit sensor. Emujo
              Sorry, posted before I saw you fixed it.
