BH Pro C500 error code SC 34-08 Started as J 31-02
  • Desert Rat
    • May 2008
    • 1089
    [Error Code] BH Pro C500 error code SC 34-08 Started as J 31-02
    SC 34-08 defines as Fixing roller paper seizure. ??
    According to the book getting four of these in a row generates this code. It just occurred to me this is a fuser code and can be
    reset through service.
    The symptoms: From tray two the paper is always skewed alot in the registration section. It does not happen from the other trays.
    I have clean all the rollers very well. I have also checked the pressure of the input rollers on the right hand side of the fuser tray.
    I ran a narrow piece of paper under the guides looking for something caught in the paper path. The tray 2 rollers are clean. The take
    away rollers are in good shape and clean.
    This unit is also giving me trouble with the FS 606 finisher. It jams the output tray into the exit rollers. I did check with a meter the
    upper limit sensor, it works. But I could not see this sensor on the I/O screen. It works ok when I send the copy to the upper output
    tray. I have not tried the saddle stitch yet.
    Any help would be of help, I am preparing this machine for a customer and am running out of time.
    DR
