Error Code Bizhub C364e C2557
  • barber782
    • Aug 2011
    • 281
    Hi, We have a C364e that has a re-occurring error code of C2557.
    I know that there is a modification for the 224e regarding this, but was wondering if this mod applies to this one.
    If not has anyone got any suggestions.
    Cheers
  • allan
    RTFM!!
    • 5463
    Re: Error Code Bizhub C364e C2557
    Check if there is no problem with your hopper, also the tube on the dev tank can clog up. I bang on the hopper with my screwdriver that fixed it a couple of times.
    You can reset the tank to operate at the current TCR level but not recommended.
    If your dev unit is at 600k and up changing it is not a bad idea.
    Whatever
    • hotfuser
      • 180
      Cheers
      The modified bushing works on the whole range. Check to see if the paddle in the toner hopper is working correctley.
      Also check the customer shacks the bottle as the toner does get compacted at the rear of the tube.
      • allan
        RTFM!!
        • 5463
        Do you have the mod number?
        Whatever
        • barber782
          • Aug 2011
          • 281
          Just been to customer. Black dev done 300k and tcr levels look fine. So.. gonna order up bushings. Checked toner hopper and pipe into dev, no sign of blockage etc.
          • hotfuser
            • 180
            Part number is A5C1RA0000 (bushing)
