Bizhub C 252
  • Tamyiapsoon
    • Dec 2010
    • 80
    Bizhub C 252
    please help , i have change yellow drum cartridge (used) and toner still full , i also have try change the toner chip , off and on so many time is error code (C-255B) still come out .
  • hotfuser
    • 180
    Re: Bizhub C 252
    Originally posted by Tamyiapsoon
    [ATTACH=CONFIG]28542[/ATTACH]
    If it is not the window at the bottom of the Image unit dirty it sounds like that will be the PWB 'M' that is failing
    • Max
      • Oct 2011
      • 560
      Re: Bizhub C 252
      You can't swap/change image units from different copier as the toner concentration will be different from image unit to image unit. You will need a brand new yellow Image unit or a yellow reset chip so the copier can calibrate itself for a different developer/toner ratio (but this method only works on second hand image units that have some life left in them)
      • allan
        RTFM!!
        • 5462
        Re: Bizhub C 252
        Good advice
        Whatever
        • Tamyiapsoon
          • Dec 2010
          • 80
          Re: Bizhub C 252
          can someone teach me how to do adjusment staberlization ? my supplier cannot support me konical minolta , customer just buy 1 month , the machine already appear error code , alrerady 4 months machine cannot use, aprreaciate .
          • wseyller
            • Sep 2012
            • 1129
            Re: Bizhub C 252
            Did you try a trouble reset. Some errors will only go away after fixing the issue then doing a trouble reset. Not sure if this is one of those codes that require trouble reset.
