Konica 7045 Key Counter Help
  • bpl3311
    • Jul 2025
    I just bought a 7045 and it asks for the Key Counter. Is there a way to get by this or reset it?
  • redhotrob
    • 69
    You need to find the connector where the external counter was connected and jump together the two wires for the copy enable. The large square connector has four wires. I think it is found on the right side of the machine under the plastic cover, then under square metal cover. I'm not which of the wires are the enable. The other wiring is for the copy counter, where a pulse is sent every copy.
    Hope this helps!
    • cod4
      Redhotrob was spot on, the wires on the link that need to be connected is the red and orange. If the original connector block is missing the Konica 7033/7040 connecter is the same
      • bpl3311
        Thanks, It worked
