BizHub fuser rebuild
  • Desert Rat
    • May 2008
    • 1089
    [Misc] BizHub fuser rebuild
    Does anyone know if there is someone or someway to rebuild or at least
    replace the rollers in BizHub fuser units? Both b/w and color?
    DR
  • Blizzoo
    • Aug 2013
    • 611
    Re: BizHub fuser rebuild
    For B/W Bizhub 250/222/223 range you can use UFR/LPR,bearings,bushings from Di 2510 fuser parts, i don't know for newer models.When it comes for Color I replace the unit after several resets.
    • Desert Rat
      • May 2008
      • 1089
      Thanks Blizzoo, that info will be helpful.
      I was hoping that the color fusers could be rebuilt.
      Hytec does not do the BHC fusers. They do other brands & models tho.
      DR
