Re: Konica Minolta C280 error C-2558
the connector needs to be plunged in while you do this there is 2 gaps on top of the connector where you can get a paperclip in leave the waste toner box out while doing this.
I found that its a plain ICP that does the reset on the chips. One of the pins is just to let the machine know the unit is set and the other pins for the dev tank is for the TCR sensor.
If made a tool from the chips with the connector from a scraped machine, just remove the ICP's and solder it to be short circuited. Put that in a case with epoxy resin and sell as a magic reset tool.
The color and black drum chips are not the same so you will need a switch that will switch between the two number 2 pins.
