OEM toner for bizhub pro 950 on bizhub 600 / 750
  • smart-refill
    • Jan 2012
    • 27
    hello
    did you try to use OEM toner for bizhub pro 950 on bizhub 600 / 750?
    thank you!
  • tulintron
    • Jul 2014
    • 668
    Re: OEM toner for bizhub pro 950 on bizhub 600 / 750
    Originally posted by smart-refill
    hello
    thank you!
    Functions normally. I have done tests on equipment and after process adjustments, showed a positive result.
    • smart-refill
      • Jan 2012
      • 27
      could you tell me, what adjustements I have to make on biz 600?
      now the equipment work with a noname toner (I think is not katun)
      thank you!
      • allan
        RTFM!!
        • 5462
        All the Konica b/w machines uses the same developer type. I use DV511 instead of DV710 on the B600 type machines, it seems like the machine is ok running on a little less developer. It lasts just as long as the DV710 and it puts less stress on the devtank. You can get up to 200K on a bag.
        So some guys will use TN710 to fill up B1250 bottles. The generic toner i use works very well and you can save a lot of money with the right stuff, or u can use KATUN if you hate yourself.
        The toner mix could be different because of the engine speed it needs to melt and set faster for quicker machines.
        Whatever
        • smart-refill
          • Jan 2012
          • 27
          allan, thanks for your answer.
          but, when you use another toner, not OEM, other "compatible" / generic brand do you have to modify any settings in service mode?
          thanks again!
          • allan
            RTFM!!
            • 5462
            thanks again!
            No, it works like the original.
            Whatever
            • smart-refill
              • Jan 2012
              • 27
              katun is not a good brand for this machines?
              what kind of generic toner do you use? could you send me a link, or a distributor?
              thank you!
              • allan
                RTFM!!
                • 5462
                Its brandless and comes from Europe. I think its manufactured by a company called GHS.
                We get it from a supplier that imports the stuff. There drums and parts are good aswell.
                Whatever
                • smart-refill
                  • Jan 2012
                  • 27
                  thank you!
                  I cannot find this brand here.
                  I'm afraid I have to improvise. I must choose between katun and OEM.
                  I will try to use OEM toner for bizhub 950.
                  • methogod
                    • Dec 2008
                    • 917
                    Running 920/950 and now 1051 and 1200/1250 for years, i would not use toner down but up may be ok...
                    I know for sure that 920/950 toner is the same and works just fine in fact we modified the toner hopper to use either toner on any type of 920/950....
                    we did the same for the 1051/1200/1250... having a mixed bag of the machines...
                    I would not skimp on Developer... its not worth replacing all consumables over $50-$100...
                    I have also found that these machines run much better with high volume - for a small business environment i would stay away from production machines...
                    go with the smaller slower 651 and 751 or a color machine...
                    less head aches...
