bizhub c253
  • big jase
    • Jul 2008
    • 136
    bizhub c253
    i have an issue on printing from this machine, copier deletes print job, when eck is switched on ..the correct access codes are in print driver also tried setting copier to print without authentication.. no joy still just deletes in job history says no authentication please help
    If at First you don't succeed remove all evidence of ever trying!
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    It depends on the security setting, but rule of thumb is. Whatever you have to enter at the machine to make a copy ie; User name + Password or just Password must be entered in the print driver in order to print. If you continually get "job deleted due to error" with the correct Authentication then you have the wrong phase driver Ie phase1 or phase2 driver when the machine is at phase3.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • KM7155
      • Aug 2008
      • 146
      i have same problem, the machine keep on deleting my print job. but my problem is just the print job is travelling out to other state and back to the machine, it show "no account for auth". but if i print thru local (no travelling out),meanning in same network, it can print. the print jobs seems lost its authentication at the different network.
      anyone can help.
      • konisolver
        System Engineer
        • Oct 2007
        • 137
        If you are using the new driver 6.1.2 you can verify the account before sending the job. This will eliminate the problem you are having.
        • KM7155
          • Aug 2008
          • 146
          try to enable the verification, but when hit the printing button, nothing to verify, just print to the printer, the VERIFY button in the authentication is disable.
          pls help.
          • popcornpuppy
            • Jul 2008
            • 29
            sounds like you need to change the settings on the machine. if you go into user authentication settings then you should see somewhere in that tab (can't remember where off the top of my head) an option to set "print without authentication"
            once you set that to on it should work fine
            • konisolver
              System Engineer
              • Oct 2007
              • 137
              That feature will only work if you have the public account "turn on." That is if you have J8 for firmware. If the public account is not enable even by turning on "print without authentication" it will not work. the job will get deleted.
              • KM7155
                • Aug 2008
                • 146
                but i need to keep track the printing account. if u enable the print without auth. then no need to enable the user auth/account track, right?
                the problem is only when the pC not in same network print to the C253, it deleted my job. if within the network, everything works fine.
                • big jase
                  • Jul 2008
                  • 136
                  this turned out to be a soft switch setting the machine was set to a generic machine not konica minolta,and using a KM driver.... i got the moon and stars loading screen not the konica minolta symbol dip 10 2 need to set on after this was changed all worked fine
                  • worthy67
                    • Mar 2010
                    • 24
                    hi i need to turn a Generic machine to a konica minolta how do you set the dip switch settings ?
                    • big jase
                      • Jul 2008
                      • 136
                      tech rep mode
                      system2
                      soft sw
                      dip 10 - 2 set to 1
