C224e / 224е
  • ivovb
    • 695
    C224e / 224е
    There is message that is shown when logged in page scope (web interface) as administrator for the first time:
    "Information Acquisition Permission
    Activating this function, enables the device to collect information regarding machine use and helps to improve operability. It also collects data about problems encountered during machine operations. The collected information will not be used for personal identification and communication."
    Can someone explain the purpose and how it works when allowed?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
  • allan
    RTFM!!
    • 5462
    Re: C224e / 224е
    It popped up a couple of firmware versions ago. It probably does what it say it does. Maybe someone can elaborate?
    Whatever
    • ivovb
      • 695
      Re: C224e / 224е
      I found it...
      Outline of the function
       When the error code or issue reported from the customer, the service engineers can
      utilize the function to acquire and save the information as the log files. In this guide
      book, the function. In this guide book, the function is explained as "Debug Log
      Acquisition function".
       Debug Log Acquisition function
      The settings for Debug Log Acquisition function is available in Service Mode. With the
      settings, it is possible to disable / enable the function, the log Type or Acquisition mode
      etc. The debug log will be encrypted when it is saved in HDD and retrieve it from the
      MFP.
       When saving the information in HDD -> The log information will be encrypted with
      using HDD Encryption Passphrase setting.
       When saving the log data into USB flash memory -> The log information will be
      encrypted with using USB Encryption Passphrase setting
      The Debug Log acquire by the system can be used analyzing the cause of the service
      call or the malfunction.
       Basic Mode/ Enhance Mode
      In Debug Log Acquisition function, two types of the operation modes, Basic mode and
      Enhance mode, are available. The procedure to select the operation mode of the
      function, setup procedure of the function and the information that can be corrected in
      the operation mode is different between the operation mode,
      etc.
      BR
