Rebuilding C451 color imaging unit
  • yianni
    • Jan 2013
    • 42
    I've rebuild a Yellow Imaging unit of C451 (I've cleaned the corona, changed opc and wiper blade). It needs to fill in (or better to change) the developer. But which developer should I use? Would the C6500 developer DV-610 work?
  • Kapral
    • Oct 2012
    • 43
    Re: Rebuilding C451 color imaging unit
    I've used DV510 for Bizhubs C350 and it worked just fine. Since I've also tried toner from Bizhub Pro C500 for C451, I'd assume DV510 will be better idea.
    • yianni
      • Jan 2013
      • 42
      DV-610Y is working well in the IU-610Y.
