Fax forwarding file types bizhub 363
  • Cookr
    • Dec 2011
    • 184
    Have a customer with a bizhub 363 and they want the faxes forwarded to there PC which I have set up but they want it to be a .tiff not a .pdf and i stoped in quickly to check it out but could figure out if there is a way to do that. I already have there scans set to default to a .tiff but i dont see a way to forward faxes as .tiff. Any Ideas? Thanks
  • emujo
    • Jun 2009
    • 3009
    Re: Fax forwarding file types bizhub 363
    To set the MFP to default to TIFF when forwarding a fax, perform the following:
    1. Enter Service Mode.
    2. Select System 2.
    3. Select Software Switch Setting and set software switch 28 to a hex value of 08.
    4. Select Fix.
    5. Select End.
    6. Select Exit and reboot the MFP.
    We see this need when the faxes are routed to a watch folder that grabs the documents for processing but only looks for .tiff formats. Emujo
    • allan
      RTFM!!
      • 5462
      emujo, where did you find a list of soft switches for this machine? i can seem to find them in the fs manual.
      Whatever
      • Cookr
        • Dec 2011
        • 184
        Sweet. Thanks emujo.
        • emujo
          • Jun 2009
          • 3009
          SM doesn't list all of them...some sort of secret info KM doesn't put out to GP. Most of the special switch settings can be found by doing a keyword search on the KM website. Emujo
          • allan
            RTFM!!
            • 5462
            Difficult to find then. I am working for a Dealership under Konica Minolta South-Africa and have access to there knowledge base. Just did the search there and got that info of of a C360 TAD. Seems like the guys in JHB in doing a good job with the new knowledge base.
            Whatever
