BIzhub C451 Print Problem
  • mindhunter
    • May 2008
    • 152
    hi fellas.
    I have this spots on my paper when im trying to print or copy.
    check th units and changing with other copier. no problem with units . ;-)
    do you have any idea what could it be this ?
    thanks a lot
  • larrio
    • Jun 2010
    • 7
    Re: BIzhub C451 Print Problem
    Looks like something is awry with the transfer belt.
    • allan
      RTFM!!
      • 5462
      Are those marks only black? Those marks looks digital.
      Whatever
      • mindhunter
        • May 2008
        • 152
        yeah its digital. and I have checked the Transfer belt.nothing that i could guess
        • allan
          RTFM!!
          • 5462
          Re-seat and reconnect the laser. Otherwise change the laser. I have not seen this on this model, I got that same pattern with B601 lasers before. Changing it was the only way to fix it.
          Whatever
          • imihm
            • Feb 2014
            • 77
            Originally posted by mindhunter
            hi fellas.
            [ATTACH=CONFIG]28935[/ATTACH]
            thanks a lot
            Hi there
            Check the fuser belt.....
            • mrwho
              Major Asshole!
              • 4299
              Had one similar to that on a color Bizhub (don't remember the exact model, but it was a more recent one). I wasn't the one who gave assistance to it, but I believe it was solved with a new control board.
              Mascan42
              Ibid
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                Had this several times, allways MFP-board gone.
                Greetings...
                • Synaux
                  • Mar 2012
                  • 1224
                  I seem to recall reading a bulletin about bad MFP board ram doing this too.
