Konica C650 jamming before fixing
  • acsolutions
    • Jun 2010
    • 519
    [Jamming] Konica C650 jamming before fixing
    Hello, I get a consistent jam under the fixing entrance. checking the jam counter it shows to be at the transfer assy. when I open the right side door the paper is folded almost in half right under the fixing rollers. When I run a test page the registration and the whole image is on the page and the paper does not seem be touching the fixing rollers. I cleaned all the rollers, vertical path and feed rollers. I ran paper from all drawers and still the same problem. Any help would be great!
  • ivovb
    • 695
    Re: Konica C650 jamming before fixing
    Can You check the code?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • acsolutions
      • Jun 2010
      • 519
      BR
      Code 3001 thanks for the response!
      • ivovb
        • 695
        Did You check sensors (PS38, PS39, PS40) and motors M2 and M30? In more cases it is dirty sensors or worn gears/bushings...
        BR
        • acsolutions
          • Jun 2010
          • 519
          BR
          Today I replaced the fixing motor assembly the transfer motor those two sensors under the fixing roller and cleaned all the sensors on the registration unit, with the same problem! I pulled the transfer/registration and cleaned those sensors as well
          • acsolutions
            • Jun 2010
            • 519
            BR
            It seems as though the reg motor fixed the problem, I believe that's the M2 motor like you suggested! Thanks again!
