Konica C554/454 Scan to email issue
  • vishop
    • Jan 2011
    • 220
    Hi Guys,
    I have a C554 and C454 on site that are having some issues with scanning to email.
    When it has not been used for a long time, say 20-30mins minimum, when you make a scan to email - it fails, details would be server connection error. If you immediately repeat the scan to email, it will be a success on the 2nd time and so on until such time the machine is not used again on scan to email. Im not sure if this is a machine settings or a network settings of the client.
    Has anyone encountered this, please share some light.
  • rrrohan
    • Sep 2011
    • 1976
    Re: Konica C554/454 Scan to email issue
    Its dns issue
    Disable IPv6
    Set the mail server IP instead of hostname
    If your already using IP ignore my above suggestions
    • vishop
      • Jan 2011
      • 220
      Hi Rrrohan,
      i checked out the machine the other day, did what you have suggested, and voila.... it worked. Scanning to email is now working even if the machine is coming from a sleep.
      thanks much
