bizhub C20 Not Installed Toner check k
  • gspanihel
    • Oct 2014
    • 5
    Message saying Not Toner Installed Check K. So replaced black toner. Still have same message. Removed all developers and drums. Cleaned all contacts. Still same error?
  • scottybbb
    • Dec 2010
    • 126
    Re: bizhub C20 Not Installed Toner check k
    Try replacing drum and toner as a set.
    • Hansoon
      • Sep 2007
      • 3379
      This will perhaps not help you but:
      http://www.copytechnet.com/forums/ko...tml?highlight=
      http://www.copytechnet.com/forums/ko...20-bizhub.html
      I had to put the machine in the dumpster BTW.......
      Hans
