bizhub error C-3B04???
  • bizhubc451
    Does anyone know what error C-3B04 is?? I have a BizHub C451. I think it might have something to do with a power surge we had in our office??
  • lvangsnes
    Sounds like it may be a finisher error. Try disconnecting the finisher, clear the code and see if it comes back. I'll have to research the exact code.
    • bgbas
      • Feb 2007
      • 60
      Here is what I found for that code
      Subject:
      Intermittent C-3B04 (C3B04).
      Description:
      Intermittent C-3B04.
      Solution:
      CAUSE: Power problem in the fusing unit.
      Solution: Replace the IH power supply (IHPU, p/n A00J-M400-03) and fusing unit coil (p/n A00J-R751-00).
      Hope it points you in the right direction.
      • bizhubc451
        Thank you! I will check that out and let you know.
        • leo
          • Jun 2008
          • 64
          its a fuser error
          turn off the powerswitch behind the little white cover
          hold down the utility /counter buttom while power on and hold it until the hourglass shows.
          after a while the displays shows a trouble reset, press it and you will get ok i result.
          power off/on again.
          if you still get an c- code please come back for more details.
          • bizhubc451
            Thank you!!!! That did it!! Wow thank you very much!!
            • leo
              • Jun 2008
              • 64
              NOP
              • Sharon
                Wow! Thanks leo!!!!!!!! I had the same problem. Your solution worked just as you said.
                • leo
                  • Jun 2008
                  • 64
                  glad to help u all!
                  • Farrukh Ahmad
                    Re: bizhub error C-3B04???
                    Originally posted by leo
                    glad to help u all!
                    I had same problem.i reset it and it works for few prints and after it gives again error..please help me.
                    • leo
                      • Jun 2008
                      • 64
                      You need a new fuser unit.
                      Or if you have one , a new heater-fuse
                      It is esyer to change the whole fuserunit but more expensive
                      • hotfuser
                        • 180
                        C-3B04 is usually the IH PU at the front of the copier. I have had a IH unit fail once that goes open circuit.
                        9 times out of 10 its the IH PU that fails.
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          Hotfuser is bang on the money.
                          Changed many of the ihpu in my time.
                          To date have only ever changed 2 coils both catastrophically failed - there was no guess work involved.
