Konica Minolta C451 - wierd printing patten - partially faded out black prints
  • thendral
    • Mar 2011
    • 82
    Konica Minolta C451 partially faded out Black prints Color OK.
    Not sure exactly what causes the issue. See the Pic. I printed full black page.
    Before I try just wanted to make sure: could it be Laser Unit or Imaging Unit? Any help is appreciated.
    Thendral
  • thendral
    • Mar 2011
    • 82
    Re: Konica Minolta C451 - wierd printing patten - partially faded out black prints
    I replaced the imaging unit, no luck. Will it be really the laser unit? if that is the case why I did not see the pattern on other colors? Any help is really appreciated. Thanks Thendral
    • lilleputte
      • Jan 2013
      • 154
      Hi.
      Have you tried to clean the print head ?
      /Lilleputte
      • DigiMan
        • Jan 2013
        • 262
        Seen this some time ago in some of these but after changing the drum unit it went away.
        I remember these machine had an issue with the black drum unit spilling developer from their back
        side,did you check that?
        I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
        • shamnad abdullah
          service engineer
          • May 2015
          • 24
          check the connections between MFB and laser unit
          • thendral
            • Mar 2011
            • 82
            I will check all of them tomorrow. Thanks a lot for all your suggestions.
            • thendral
              • Mar 2011
              • 82
              OK I was able to fix. Just to let everyone know - It is laser unit. There seems to be some toner / dirt in the pathway causing this weird pattern.
              Once I clean it and put it back it prints good.
              Thanks a lot to lilleputte, DigiMan & shamnad abdullah. Keep up the good work. Its a great help.
