Biz Hub 423
  • antone
    • Oct 2014
    • 344
    Biz Hub 423
    Tray 1 only jams 11-01 1 changed paper feed rollers ....paper never feed up vertical transport tests 2,3,4 feed
  • allan
    RTFM!!
    • 5462
    Re: Biz Hub 423
    I am am having something similar but the paper feeds just short of the registration roller, even loop adjustment is out of range to catch it. All other trays work fine. I have replaced all the rollers, clutches and the torque limiter.
    The motor drive is in the same chain as the other trays so its not that. Its not the Path or common relay rollers. It worked before. Ended up removing priority from tray 1 for a work around.
    This is where trouble isolation works well until or if ever it will be fixed.
    The contract expires very soon.
    Would be nice to be able to fix it.
    Where does the paper stop exactly?
    Whatever
    • copyrooks
      • Oct 2013
      • 210
      Re: Biz Hub 423
      I would try another registration assy from another machine. In some cases i've seen tray 1 jam and then throw a paper size error message. After replacing the assy the jamming problem was gone and the paper size error never appeared again. good luck
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: Biz Hub 423
        for the first guy...
        There is a dinky clutch on the feed units, it goes bad
        • imihm
          • Feb 2014
          • 77
          Re: Biz Hub 423
          Hi there...
          Such problem happens when the feeding clutch goes faulty..just replace it..
          Thanks...
          • antone
            • Oct 2014
            • 344
            Re: Biz Hub 423
            Replace Clutch and one way gears
            • allan
              RTFM!!
              • 5462
              Re: Biz Hub 423
              The registration sensor sticks and drops back if you open the door. I had this problem a couple of times. Remove the registration unit and clean the flag ends with a lubricant.
              Whatever
