BH 224e T-18 Fax error
  • splblazer91
    • Jul 2014
    • 204
    Anyone have a fix for this? I have already initialized the fax unit and still get the code randomly.
  • allan
    RTFM!!
    • 5462
    Re: BH 224e T-18 Fax error
    What is the specific error code you are getting?
    Whatever
    • Choclit007
      • Oct 2010
      • 58
      T00
      • Check to see if the destination is correct.
      • Check the state of the recipient.
      T05 Check the state of the recipient.
      T08 Check the line status.
      T18 Check the state of the recipient.
      T28 Check the state of the recipient.
      T32 Check the line status.
      T42 Check the line status.
      T43 Check the line status.
      T48
      • Check that the fax number registered with the recipient is correct.
      T58 The document to be sent by polling is not registered in the sender's machine. Ask the sender to set the document.
      T60 Register the document that is sent to the recipient by polling.
      T61 Check whether the document to be sent by polling from the bulletin board is registered.
      T62 Inform the recipient of the correct bulletin board number.
      T80 Check the line status.
      T81 Check the line status.
      T82
      T85 Check the line status.
      T89 Check the balance in the billing management device.
      T95 Check the line status.
      T97 Check the state of the fax board. (Contact your service representative. )
      T98 Forwarding is not available for that combination. Check the forwarding settings.
      T99 Check the destinations registered in the address book.
      R18 Check your machine. If toner or print paper is empty, supply them. If the memory is full, empty the memory.
      R21 Turn the Closed Network RX function off, or inform the recipient of the correct password.
      R22 Turn the Closed Network RX function off, or inform the recipient of the correct password.
      R32 Change the setting for Auto Create User Box, or inform the recipient of the correct Confidential User Box number.
      R50 Check the line status.
      R60 Check the line status.
      R63 Check the line status.
      R69 Check the line status.
      R72 Ask the sender to shorten the length of original to be sent before resending the fax.
      R78 Turn the Main Power Switch off and back on.
      R79 Turn the Main Power Switch off and back on.
      R93
      • After checking with the sender, register a Confidential User Box for confidential reception.
      • Check the password for the Confidential User Box.
      R94
      • After checking with the recipient, register a Relay User Box for relay distribution.
      • Check the password for the Relay User Box.
      R95 Check Forward TX Setting.
      R96 Inform the recipient of the correct number for the Confidential User Box.
      R97 Check PC-Fax RX Setting.
      R99 Turn the Main Power Switch off and back on.
      • splblazer91
        • Jul 2014
        • 204
        BH224E manual says check recipient, check paper tray or memory. Customer gets the error when faxing to several different numbers though.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          do you have any way of testing the transmission level over there ?
          Here we can send a test fax to our local carrier and get a report back and adjust accordingly, when it actually works..
          • splblazer91
            • Jul 2014
            • 204
            Not that I know of. Phone companies here tend to be a pain to work with.
