C754e PDF Print Speed
  • eunos
    • Mar 2015
    • 9
    Hi all,
    I'm using a batch print program (Print Conductor) to print bundles of documents.
    Each document has a tabbed divider inserted before it as a front cover from the bypass tray.
    When printing, there is a lag of anything between 1 to 5 minutes before the document prints, whilst the blue "receiving" light is flashing on the machine.
    I really need to find a way of reducing this lag to speed up the prints. The documents being printed range from 250kb to 3mb.
    If I can get the documents to spool up faster, then I will have found a quick and easy way to insert tabs into a print run, as the method of doing so through the driver is rather tedious and has a limit of 20 inserts.
    I'm using Win 7, PS driver, and connected directly to machine via USB (and unplugged ethernet to stop others printing mid stack)
    Many thanks,
    Ben
  • Max
    • Oct 2011
    • 563
    Re: C754e PDF Print Speed
    Update firmware to latest, install pcl driver directly to your PC so your job doesn't have to go via a server and print via network not usb. There are a few things you can change on the driver but try those things 1 st.
    • allan
      RTFM!!
      • 5462
      I agree the PCL driver works best with MS.
      Whatever
      • eunos
        • Mar 2015
        • 9
        Thanks very much guys! I've switched to the PCL driver and it has made an immediate impact.. The delay between documents starting to print is now a matter of seconds rather than minutes. That's great!
        Now I just have to figure out why Print Conductor occasionally fails to print documents which then ruins my collated print sequence.. Can anyone recommend a better batch printing tool?
