C6501 direct connect
  • RaptureKing
    • Jul 2025
    Is it possible to connect a c6501 with an ic-408 straight to a pc with no internet or phone line?
  • Sergey_Lyubik
    • Mar 2015
    • 4
    Re: C6501 direct connect
    You can use a crossover cable
    • Mick01
      • Nov 2012
      • 362
      Yep you can (do it all the time when testing)
      As with the previous reply you use a cross over cable directly connected between the PC and the IC-408. Most network cards are auto switching now so a normal cable may work.
      The PC needs to be within the same IP range as the IC-408.
      • RaptureKing
        How do I get the pc to be in the same range as machine an also when the crossover cable is in my laptop I can't connect command work station to machine won't find IP
        • Sergey_Lyubik
          • Mar 2015
          • 4
          Which IP addresses in your controller and your laptop?
          • methogod
            • Dec 2008
            • 921
            you will need to set your IP manually... i know crazy...
            takes 5 minutes if you have common network skills...
            best bet is just to use same ip that network is on.
