Konica 7165 toner type?
  • bejoyjohn
    • Nov 2008
    • 45
    I founD A KONICA 7165 with Tn 601 toner full bottle but asking for toner. I am not used to this model so will anybody tell me is this the right type of toner if not please tell me which type it is? I will be eternally thankful.
  • allan
    RTFM!!
    • 5462
    Re: Konica 7165 toner type?
    TN601K is the right toner. Maby the hopper is broken?
    Did you remove the seal?
    TN710 toner should be the same powder. I'm just not sure if the bottle will fit.
    Whatever
    • CraigW
      • Dec 2010
      • 417
      Make sure it is opening the bottle when pushed all the way into place (sliding sleeve)
      The slot for the very back of the toner bottle (at front of machine) is molded 2 different widths.
      • tech51
        • 846
        Does the bottle rotate after it's been inserted? If not then chances are the drive gears are broken. Cheat the toner adding door and have a look.
        • bejoyjohn
          • Nov 2008
          • 45
          The end where bottle goes into the machine is not looking like meshing withe machine . thats why I doubted thats the toner type.
          • Mick01
            • Nov 2012
            • 362
            Although it is the right toner, the bottle could be for a different region. Different region bottles have different size slots that the toner hopper engages.
            • CraigW
              • Dec 2010
              • 417
              Is it not meshing at the business end (at rear of machine) ?? Or at the front of machine where the round end of toner bottle cradles in ??
              The sliding mech opens and closes the sleeve at business end with removing and inserting of the tray. (this may be where problem lies with enthusiastic customers) Easy to mangle stuff.
              • bejoyjohn
                • Nov 2008
                • 45
                At the business end. its end does not look like the ____ ____ but like an out of shape polygon.
                The nbusiness end of toner looks like ____ ____ .
                • bejoyjohn
                  • Nov 2008
                  • 45
                  No TN 710 does not fit. I tried.
