Remote key pad
  • emujo
    replied
    Re: Remote key pad
    You must enable SSL, CE Authentication ON, complex admin password. Once these settings are correct, your remote panel settings will show up in ADMIN/NETWORK. Under remote panel client, set to on. From web browser..https://IPADDRESS:50443/panel/top.html Another way to access the control panel is to download the Bizhub Remote Access from google play. As long as your android is on the same network as the MFP, you can operate the control panel. Much easier process. Emujo
  • bineeshgeorge
    started a topic Remote key pad
    Remote key pad
    Hai.
    My bizhubc224e shsows touchscreen problem sometime. Please explain me to access key pad in computer.The settings in computer and machine
